How do you unstick the heater/defros levers?
pauls340
17 miles N of Detroit
My heater and defroster levers slide left to right very tightly. Now that the dash is open, is there a good way to lube it? thanx
Prob'ly not the levers/ mechanism, but rather the cables.
start with carb cleaner--- coat the cables-- then use a spray lube--- slowly work the cables back & forth-- should notice a difference after thsi ,Lawrence
