How emergency brake cable conencts to emergency brake lever
Sirsmiley9
Florida
I didnt get enough pictures of the bottom assembly of the brake, and i dont see how the cable actually connects to the metal piece.
Is this what your referring to?
No sorry it’s where the cable itself ends in the brakes and is supposed to connect to the metal lever that is connected to the shoe
I saw that bent piece didn’t think to slide it through though I’ll try that really quickly
Hello Sirsmiley9
It connects to the bracket (lever) that is on the back of the shoe. The pictures are of the passenger side.
Hope this helps,
Stay Safe.....
Happy Mopar :)
Arron.
you need to push the spring away from the feral. a medium sized pair of needle nose pliers will usually work
