j par
It's nice that that their shows it doesn't touch the oil and also there would be oil being sucked out of there at the time the crank would be going around? With that said is there a need for a windage tray?
My race x block has no provision for a dip stick. Rather than drill a hole for one, I put a sight plug in my oil pan. I measured from the pan rail to the bottom of the wind age tray and placed my sight plug in the middle of that distance. This way I know the crank is not dipping into the oil level. No where's near the seals.I was wondering at what point does it start pushing against the seals? Like my 8 quart milodon oil pan, if I was to lay on the ground face up and pour oil in it at 8 quarts would it make it up to the seals?
I reckon when installed there's things like the pickup tube that are displacing oil.
I'm just never tried it.
Thank you for your experience.
.I put a sight plug in my oil pan. I measured from the pan rail to the bottom of the wind age tray and placed my sight plug in the middle of that distance. This way I know the crank is not dipping into the oil level. No where's near the seals.
I didn't have a stock dick stick to put in it cuz obviously those always get destroyed coming out if they're even salvageable. so I bought one of those cheap Chrome tubes with a dipstick off of summit or something. I have an entire thread dedicated to when the stroker ate that first dipstick and all the pictures a long time ago. So now I just put the measured amount and a little stubby 6 inch lo dummy dipstick with a spring attached to it so it can't fall out.My race x block has no provision for a dip stick. Rather than drill a hole for one, I put a sight plug in my oil pan. I measured from the pan rail to the bottom of the wind age tray and placed my sight plug in the middle of that distance. This way I know the crank is not dipping into the oil level. No where's near the seals.
I know on a trans pan, the static level is about 1/4 inch above the pan rail where it will seep out the dipstick if allowed. Oil pans should be easy to figure out, just put the dipstick in and youll get a rough estimate where the static fluid line is. Used to be a good indicator of whether your trans dipstick O-ring was bad was if it leaked over night but not while idling.
It also creates a slinging oil rope traveling around the crank at blinding speeds, costing some h.p.But wouldn't that be well lubricated?
The only part of the crank that needs lubed is the journals. However the oil falling down from the upper part of the engine that hits the crank is cooling the crank.
Windage tray breaks up the windage in the pan area and scraps rhe excess oil from the rotating assemble.
Sooo, I believe I have the stock dipstick to check the oil with the summit Chrome cheap tube. when it gets about a half inch from going all the way and it feels like it hits something and I have to twist it and bang on it till it passes it and can go all the way in? Probably whatever that is the crank? I believe, I don't know why still?
really, I didn't know that!you do know that 5qts of water is more than 5 qts of oil, right? lol
Sorry I did not explain that very well. The middle level of the sight plug is at the level of the oil that my measurements told me would keep the wind age tray and the crank throws out of the oil..
How would that work?
If you fill up to the sight plug the bottom of the windage tray would be under oil.
Wouldn't it work better to measure from the bottom of the pan ro the bottom of the windage tray. Then put the sight plug below the windage tray.
Like a motorcycle...Sorry I did not explain that very well. The middle level of the sight plug is at the level of the oil that my measurements told me would keep the wind age tray and the crank throws out of the oil.
To check my oil level I just look at the sight plug. I used a sight plug for an air compressor.
I went through this exercise with my recent rebuild of my 340.
I have the Milodon #30935, 8 qt pan.
The photos are with the pan filled with 8 qts of water.
The water level is 4 inches down from the pan rail.View attachment 1715227004 View attachment 1715227005 View attachment 1715227006
And I already know the obvious just note where on the dipstick is at 8 quarts and make a mark.
j par are you overthinking things again?
If you have the oil level at the rear seal your crank would be about half way under oil.
The farther the oil is below the crank the more power the engine makes.
Do some study on oil control and effects.
I added all of these Quotes before i add this link. which i fill it appropriate for this discussion.
Engine Masters: Season Season 3, Episode 32 - How Oil Kills Power! | Motor Trend
After i watched this, i have decided that i only need 2 Quarts of oil!.... in my rideJUST KIDDING!!!!!!
For those that don't want to watch this video. You don't want 8 Quarts in a 8 Quarts pan. because of windage and it can cost you up to 20 HP because of it. also will lose some oil pressure at top rpm do too air in the oil stream![]()
