is there in a '87 Small Block Distributor Mechanical advance plate? I have heard everything from 20° to 25° all the way up to 34° because of the ported vacuum set-up. Is there a differance in the vacuum canister older verses newer? Can that '87 Distributor be re-programmed (I.E. changing the weights and springs on the advance plate) to early, pre-emissions. settings? Is there a vacuum canister for the Small Block Distributor that will fully deploy at a lower vacuum, something on the order of 8" HG?
Bob
Bob
