360moparjunkie Well-Known Member Joined Dec 24, 2009 Messages 252 Reaction score 34 Location Ceres, CA Jan 12, 2015 #1 Just need to know how much to buy. Im thinking like 2 gallons or so. Probably need a little more for the deeper pan. Thanks again. Attachments 1421118134619.jpg 23.8 KB · Views: 171
70aarcuda Master Hoader of SBM Legendary Member Joined Jan 16, 2005 Messages 16,639 Reaction score 5,967 Location las vegas Jan 12, 2015 #2 If you are starting dry....new converter and cooler lines....I bet it will take almost 12 qts... i would put in 6-8 qts...start it up in neutral...and add to almost full line.... run the trans thru the gears...and check it again...
360moparjunkie Well-Known Member Joined Dec 24, 2009 Messages 252 Reaction score 34 Location Ceres, CA Jan 12, 2015 #3 Great. Need just enough for t converter to bolt it up for now. Good price at wally world on the type f. Thanks again!
