mrtires24
Hey everyone. i am just wondering if anyone would know how much horses My engine might be
here is the info.
Engine is a 440
3698830-44-9
sept 18 1972
It has a forged crank
it has been bored .30 over with forged magnesium pistons. Flat top. i don't know the brand. But I pulled the head off, and I was able to see them
My heads are clean, and look like they have zero miles on them ( so does the hole motor for that matter) Heads are 3462346 2702
and i have these numbers writen down
346 ( I don't know why I wtote this one down
valves=2.08
1.74
camber=79
81
My cam is a crane cam h272-2
Details of it is best @ 1600-5400rpm
part # hmv-272-2-n6
04-30--88
272 intake duration
284 exhaust duration
0.45 intake lift
0.48 exhaust lift
Good idle
Hydraulic lifters
adjustable crane pish rods
double timing chain.
I DID NOT BUILD THIS ENGINE. I bought it, took the heads off, and took the timing chain off and removed the cam. i put it back together once I saw these parts. It looks like it has 0 miles on it. The cam is a used cam, but the cylender walls still have the X marks from the rebuild, and the intire engine is grease free with new frost plugs, and no oil inside it. just pre lube.
I don't know anything else about the engine, I am jus wondering what it might be like befor I have it running.
I don't know the compresion yet.
I will have it in my 4 spd duster with 323 posi.
thanks
Phil
here is the info.
Engine is a 440
3698830-44-9
sept 18 1972
valves=2.08
1.74
camber=79
81
part # hmv-272-2-n6
04-30--88
272 intake duration
0.45 intake lift
0.48 exhaust lift
Good idle
Hydraulic lifters
thanks
Phil
