MRL you are right in the fact that they aren't the right rod for the app. that wasn't the question. I knew in fact that they aren't the "best choice" but it's what I already have. I mainly wanted to see if anyone had seen any failure on these rods with high HP motors. I see at least 2 others running similar combo's without failure. I know there is no one in there right mind that's going to tell me yes your rods meet or exceed your needs if you where to run 7K+ and you intend on getting 300 passes and the motor will be fine. I do thank you guys for your input and I do agree with all the things you said MRL but I think you took the question the wrong way. I didn't ask if I where going to build a motor what should I use question? If I where building a motor from the bottom up and I will but not this year I would use an H beam rod intended for that type of stress.
