Just got my motor back from the machine shop. I went from a eddie headed 420" cast crank 10.2-1 compression to a eddie headed 422" 4340 crank 11.65-1 compression motor. Now for what I changed, went from a stock eddie 2.02/1.60 valve to a lightweight ferrara 2.08/1.60 valve. Also went to a smaller diameter comp cam double spring. Was using a 1.470 diameter double spring and now a 1.250 spring my engine builder is using on alot of ls stuff (he couldn't say enough good things about this spring). Also went with a much lighter lifter about 30 grams less per. Piston weight was a 623 gram solid dish vs. 510 gram flat top both are Diamond. Crank was a 4.00" cast mopar performance at 62 pounds and now a BPE 4.00" 4340 at 56.8.
