How much will my cam effect my carburetor build?
doogievlg
Amelia, Ohio
My engine is off at the builder but in the mean time I was going to rebuild the Holley that would be sitting on top of it. The Holley is a used unit off Craigslist so I know NOTHING about it right now. Should I wait to hear what the build recommends on the cam before I start building the Holley?
Engine is a .30 over small block with flat tops and aluminum heads. Carbuerator is a Holley 750 DP.
which small block? big difference in requirements between say a 273 vs a full out 408, 360 based stroker.
My mistake. 360.
might be a tad big but i'd run it and jet it to what you need. that said, i'd wait on the cam and then ask them what they think as far as jets. I'm running a 670 on mine but its in a truck
What was wrong with it? Did it run bad?
The carburetor? I bought it off craigslist for 100 bucks. I don’t trust it and I do not want to show up to the dyno with a carbuerator that I know nothing about.
Very generally, its going to be effected like this:
The idle to part throttle works on the pressure difference between atmosphere and the intake. That is, manifold vacuum. A cam with significant valve overlap for the displacement will have less manifold vacuum at idle. The larger the primary throttles, the more difficult it is to get the vacuum signal needed. So for that, and the exhaust reversion, need to set the idle fueling to address that.
The main circuit works on pressure difference created by the air velocity going through the boosters. The slower the velocity, the less the pressure difference and therefore the main air bleed and jets may need to be adjusted when using a larger venturi and booster for a given size engine and volumetric effeciency.
What you can do is get a copy (used) of Urich & Fisher's Holley Carburetor's and Manifolds to have good reference on all the basics, what the passages do, etc. Then if you're up for it, get set of micro-drills and full set of the normal size numbered drills. Use the shank ends to measure and write down all of the restrictions.* The main jets are marked by flow, so no need to measure. Then you'll know its clean, gaskets are good, the floats are at a good starting point, and you'll know what its got inside.
Adjust the throttle position for something between .020 and .040". Write down how many turns this took because when you start the fresh engine, you may crank this up to whatever is needed to keep the engine running at break in rpm. But then you need to bring it back down to something between those numbers to start tuning.
*example of a nicely done table of Holley internal air and fuel restrictions here:
Mild Ford 289 Tune | '37 Pickup Cruiser - racingfuelsystems.myfunforum.org These will make more sense later after reading about the carb circuits work. Chrysler did some booklets on how carburetors work, you can find them on-line at www.Imperialclub.org but I think Urich is the easiest and clearest for 4150s.
Great links man. Thank you
open it and use the factory jets for the list number, that is the starting point. power valve depends on cam/vacuum
