GAMoparMan
Hey Guys, I picked up another 73 Duster 340 and trying to figure out how rare it is. Its painted JF1 Mist Green. I've done some searching myself... The Color is hard to find information on.. Its a 1 year only color and 1 source says 250 were built in that color. Which equals out to like 1.7% as Mopar likes to use the % format.......And then researching the V21 option only turned up quotes of it being rare for the year also. Any additional information that other members can provide would be much appreciated.
Here's a Run down of the Fender Tag:
Code
Description
E55
340-4 Barrel 69-73
D13
3-Speed Manual Transmission Floor
VS29
V = Plymouth Valiant / Duster
S = Special
29 = 2 Door Sports Hardtop
H3B
H = 340 240HP(net) 1-4BBL 8 CYL
3 = 1973
B = Dodge Main, Hamtramck, MI, USA
142144
Sequence Number '142144'
JF1
Paint Code: Mist Green
D2F6
Trim Grade/Style/Color
D = Deluxe
2 = Vinyl Bench
F6 = Green
000
Upper Door Frame: Full Door Panel
914
Date Built: 9 / 14 / 1972
099802
Order Number: 099802
JF1
Roof Type OR Color: Mist Green
U
Built to Specifications for USA Order
B41
Front Disc Brakes
G37
Left Hand Remote, Right Hand Manual Chrome Mirrors
J52
Inside Hood Release
M21
Roof Drip Rail Moldings
N76
Coolant Recovery System
R11
Music Master Radio AM
V21
Performance Hood Treatment
V6X
Black Longitude Sports Stripe
V8X
Transverse Stripe - Black
26
26 in. Radiator
EN2
End of Codes Assembly Line 2
I also found the Build Sheet for the car...Its alittle rough, I'm in the process of recording the codes over onto a user-created blank for my personal records/showing.
Thanks
Daniel
Code
Description
E55
340-4 Barrel 69-73
D13
VS29
S = Special
H3B
3 = 1973
142144
JF1
D2F6
D = Deluxe
2 = Vinyl Bench
F6 = Green
000
914
099802
JF1
U
B41
Front Disc Brakes
G37
J52
Inside Hood Release
M21
N76
R11
V21
V6X
V8X
26
26 in. Radiator
EN2
Thanks
Daniel
