Same here.........The lead works, but it's a real pain to get started....takes a little patience.........you can do it with nothing more than a small tip propane torch and some practice........BUT, I prefer the mig on low amps.......a larger hole gets a small plug tacked in and then beaded (one tack at a time to avoid warping), then grind and finish......you can tape 1/2 of your little plug onto the hole, then tack weld it....then remove the tape, and continue.
If you try your hand at leading, be SURE the holes are ground clean, including the inside lip, and then cleaned with solvent before you start. Most guys would VERY LIGHTLY tap the hole with a small ball pean, or even a philips head to give them an ever so slight concave to fill with the lead......just don't hit it too hard or you'll have big dents instead of tiny holes........I'd simply ream the hole a bit with a larger drill bit......worked nicely (on very slow speed for control).
:read2: Good luck.
