72ScampTramp
Scamp Tramp
Ive got a blown head gasket. I Pulled the valve cover and 5he underside was like sludge. Like green snot. I can only assume the entireally engine is like this. How can I flush it out after repair?
Not trying to promote undue fear, how long do you suspect it was leaking? Was the oil thickened as a result? The reason I bring this up is that coolant in the lube has the ability to strip the outer (softer) materials from the bearing face.
If this was to the point the oil was thick, I would certainly think about pulling the pan for rod/main inspection.
Good luck, hope it shakes out in your favor.
