gdizzle
So on the 66 dart, which has been repainted a few times, I removed all the ruined seam sealer at the roof drip edge. And found some rust right on the inside corner of the drip rail to the roof. I tried my 2in wire wheel, and it is not doing anything to it. I bought the 4.5in flapper sanding/polishing 80grit wheel for my angle grinder, and it can not get inside the corner, and can hardly even fit in the drip rail channel. Is there something else that can get in there? I do have a multi dremel tool with the triangle head, they do make a grinder disk for it, will that work?
I suppose last resort is to just use the angle grinder with normal grinder disc, but I am afraid it is going to go too deep and cause more damage. Ideally I am just wanting to grind out the rust, prime it then reseam seal it. I do not want to have to do bondo. Any ideas? yes I've tried a screwdriver to chisel but not working.
