cascius
So I bought this '69 Dart because I need another project like a hole in the head. The body is pretty rough but it's supposedly got a warmed over 360 in it. I can't verify the internals but the outside has some nice parts on it. A previous owner hacked the wiring and then spray bombed the entire engine compartment so you can't even tell wiring colors. I just want to make sure the engine runs ok before I spend the time to put it in my Duster. I'm wondering if there's any easy way to hotwire an electronic ignition system to make it basically a standalone system. The ignition switch wires area all cut and they tried to wire them to a generic switch with no luck. Thanks for any help.
