How to Install Camshaft Bearings
How do you handle it if there is a bit of drag after they are installed?
I take an old cam core and cut a diagonal slot in each cam journal face, install the cam and turn it until it frees up . The slots act as a cutting edge and remove just enough material to get the clearance right.
That's a good suggestion. I've got an old folding knife in my toolbox that works great for a bearing scraper to shave any high spots. Thanks for the write up.
Leave it to me, doing things the hard way. I tried the cheap'o route with the threaded rod and washers. Worked well for removal, installation was a whole different problem. Needless to say I trashed 2 of the bearing and ended up buying the tool and another bearing set. $40 in the trash. Thanks for the article, big help 2nd time around.
Cheers,
Just got the same tool in off of Amazon. Just took out the cam bearings on a 350 chevy. Going to do a R and R on my 318 hopefully this weekend. The tool works great! Not cheap but not cheap Chinese crap either. Worth ever penny.
Great article. Thanks for sharing.
