How to Order the E-4 Cam?
eekvonzipper
My Member is Legendary!
Cadet, Missouri
Does Anyone here have any Part No#'s for the Isky E-4 and Lifter Set?
The Site is hard to Navigate, Nothing say's E-4 on it and Typing in SB273 will get you nowhere
I can Order a Flux Capacitor for a DeLorean online with No Problem,
But finding a Cam for an old Barracuda is another story.
Scroll down to about page 122, it shows that cams part number and all the sprcs. Pretty sure no matter where you order it from, either through Summit or even directly from Isky there will likely be a delay, unless they got a batch of cores in recently. I would call ISKY to find out the status and then order it from Summit, as it will be cheaper that way, at least that’s what I’ve found when ordering a catalog grind from them.
https://iskycams.com/downloads/IskyCatalog.pdf
That Helps, Thank You!
It shows the Lifters for it are $275 Dollars!!! :wtf:
I used Howard’s on the hydraulics, but for that E-4 cam I’d use Howard’s EDM solids.
It shows the Lifters for it are $275 Dollars!!! :wtf:[/QUOTE]
That seems expensive but… price some crane ultra pro rollers then the price don’t look so expensive :lol:
Get your factory lifters refaced!
How this thing going to get refaced?
:rofl:
The 275 lifters are the mid grade, you could get the tool steal ones, 500 and change...:lol:
Use the Comp 270S. Easy to get.
Lifter refacing...
Don't call John at Costa Mesa R&D as he passed in 2018. But do scroll down and view his videos. You will learn a lot.
You get the lifters refaced, not the cam. I hear people talking about Oregon cams on this forum, maybe he can do it.
