How to remove exterior chrome/stainless trim w/o damage '65 Barracuda?
What are you looking to remove. Most all the trim is either bolted on or uses clips to secure the trim.
The drip rail trim is what is usually inquired about. I use a small block of wood and a hammer. Tap on the bottom edge
with a small wood block. Refrain from using metal tools as they can distort or scratch the moldings. You might want to start with the A pillar moldings first. Patience is key to removal without damage. Depending on year and model,
trim may use squeeze fasteners, studs with nuts, screws or pry off, or any combination. The top of 1/4 panel trim
on the Barracuda should be squeeze fasteners with a few studs and nuts.
I'm going to strip everything for restoration. I will follow up on toolmanmike's leads first and get back here if/when I need more specific help. Thank you.
