It's been years since I've had mine off but believe the long trim will just pop off the clips after removing the fender guides. There may be a clip with a nut on it that you might have to access from the rear of the fender by the door. The fender guides are secured from the underneath. I believe you'll have to remove the front fender shields to gain access.
