65cudasteve
- Joined
- May 17, 2010
- Messages
- 46
- Reaction score
- 0
ok guys i need help once again...just like the title says how do you remove the torsion bars off a 65 formula s cuda??? show pics if you can thanks!
cudasteve no need for a welder,just a drill .I made mine a bit more robust as I've used it often .If it's a one time deal you could probably make one for less than $10. But that's just me I'm cheap that's probably why My car still isn't done ! LOL.65cudasteve i found one for 34.95 that is not on ebay and jomoper i dont have a welder at my house i work at borla.
can someone explain pre loading? im getting nervous now that mine are in.... i can only go it one way and with the adjuster and paw ALL the way down...slide it in then put back together right? i noticed whe trying to get it in only one postion was close to match and fall in then add the pressure...did i miss something on the 30 degree etc?
i really need to invest in one of those FSM's i dont have one. lol sorry for all the questions
You don't HAVE to buy them if .pdf is OK, you can download 'em free
here
http://www.forabodiesonly.com/mopar/showthread.php?p=1970088617
and more here
http://www.mymopar.com/index.php?pid=31
As AbodyJoe said DO NOT nick the bars. This means no pipe wrenches, vise grips or any other kind of pliers or ANYthing which scratches and nicks the surface
You CAN get these out without the removal tool. Remove the strut rod nuts, remove the pivot nuts, and get a big-azz pry bar. Get up in there and pry between the front of the lower arm and the K member to force the lower arm pivot 'to the rear.' It will push the bar out. Don't forget to remove the bar retainer clips, two wire clips at the very rear of the bars
WOW 2015. THIS came waltzing back from the dead LOL
for what it's worth, mine that had been in the car since new (48 years) just slid out.also i dont have the removal tool and i need to drop the k frame and put the new one back in but i dont want to damage the torsion bars though so where can i find this removal tool??
