How to remove trip reset knob from dash bezel?
cgfen
Vista CA
Is it is simple as pulling it off and re-gluing?
I don't want to just pull without a bit of confirmation.
I want to remove the bezel from the gauge cluster to clean / re-fresh the gauges and needles.
Thanks
Craig
Yup, pull the knob out while turning it to the left (counterclockwise). It should break loose. Release the knob and unscrew to remove it. Hopefully some previous knucklehead didn't glue it on like one I found!
Good info.
Thank you.
So easy to remove when you tell me the path.
