before I would go buy any acid, I`d do what trailbeast suggested, you`d have it out before u could get home w/ the acid, "IF" u could buy it !
Interesting. Are you saying that the heat from the MIG tack(s) expands the tap, and upon cooling it will fall out?you can drop a bead in it with a mig welder. as it cools, it'll fall out, and you can carefully drill the remainder bolt away.
Can't wait to try it.Nope, I'm saying the head from the bead goes in at a certain temperature, and with contraction upon cooling, the offending ez out will shrink n' loosen. The hard part is not welding it to the bolt it's stuck in. The acid method above sounds awesome if in aluminum.
The weld bead method works EXTREMELY well for bearing races pressed in to housings. Lay a bead and wait a minute. They'll fall out.
