My window regulators are in good shape, but there is surface rust on some parts. I won't media blast due to the risk of the media getting into critical mechanism parts. I've solvent cleaned them and got all old grease off, used 3M red scrubby pads on the rust, but there's not much else that can be done without disassembly, which I am not going to do. should I just clearcoat them, lube and install, or stainless steel paint, lube and install? No coating, just lube and install? Use Ospho on the raw steel parts? Am I overthinking this? Not visible once installed. What have others done?
