How to snap of center of rallye rim?
Richard McLaughlin
1974 Duster 340
New Brunswick
Do these center parts come off? I thought the bolts that hold the rim on were holding them on but I guess not. Gona leave the centres chrome and black out rest.
Thanks!
If you look at the back of the rim around the center there should be 3 5/16 head screws that hold the center cap on. Remove those and it should come right off.
Screwed in from the back side. The trim rings just pry off.
The center cap or the round center? easy to see how things can be misread.
What was self explanatory was the OP thought the lugs held the part to be removed on, that rules out the round center insert immediately.
I put a dab of clear silicone on the shoulder of the screws after I refinished my wheels. They occasionally come loose and rattle.
I screwd both bolts on. Seems tight. They probably rattle loose. Previous owner had cardboard stuffed inbetween the cap and the rim. But it looks like the screws just needed to be tightened.
