I'm working on diagnosing a no-spark/insufficient spark situation on my '69 225 (Valiant 100), and when trying to check for slack in the timing chain, I realized that there isn't any center bolt to allow me to turn the engine with a breaker bar:
Thus leading me to the question: How do you fellows spin one of these by hand? Pull the plugs to overcome the compression resistance?
This also brings up one other question: I found the TDC/5/10 degree marks on the timing chain cover, but I don't know what signifies the 0 TDC mark on the pulley. There is a spot on the edge about 1" wide that is flattened out - am I to assume that the center of this flat section is supposed to represent 0 TDC?
-Kurt
-Kurt
