TrailBeast
AKA Mopars4us on Youtube
Working with a 1996 5.9 Magnum with a regrind cam 214/224-.512 lift.
Ever since I put this thing together I have had a very tiny rocker/lifter tick on #6 or #8 (can't tell until I open it) and yes I am sure it's not an exhaust leak.
I assembled it with about .040 on the lifter preload which apparently is close to the minimum recommended preload.
Current factory pushrods are 6.915 +/- .020 from what I have seen.
I can get a killer deal on these.
Pushrod; Magnum 5.2L/5.9L; 5/16 in. Dia.; 6.936 in. Long;
FEATURES:
Since the stock pushrods are hardened would you try swapping the existing rods to a different lifter and see what it does? (a no no generally)
Or, would you get the longer pushrods and push the preload up to it's high limit of about .060?
I'm wondering if maybe it has a lifter that doesn't like the .040 preload and a rod that is on the short side of the specs, and swapping that rod off that lifter may do it.
Thanks
FEATURES:
- Case-Hardened Tubing
- Surface Hardening
- Welded Ends
- 0.3125 in. Diameter
- Use with or without Hardened Steel Guideplates (which I have)
Thanks
