Howards Hyd roller cams
Rat Patrol
On the outskirts
Just fishing for any information or experience with these cams?
The web site is appalling - no valve spring or lifter recommendations....but the cam made good power with some ported J heads on my Dyno Sim....
cam is - http://www.howardscams.com/index.ph...egory_id=218&option=com_virtuemart&Itemid=114
235/241 @ .50 .530 lift.
Here's the sim..the head flow figures are for the Js on Shady Dell.
well..the lifter recommendation should be pretty easy....hydraulic roller....lol
If this is a roller block, just use the stock replecements and make sure the oil hole points towards the valley...
Never heard of Howards.
I would recommend using a Hughes cam. We just bought one for our 91 360 with hydeaulic rollers. I hear Hughes run great. My brother in law put one in my brother's old AAR Cuda and was very impressed with the power. Hughes will also give you a valve spring recommendation.
Howard cam has been around since the early 50s and make a very good product. They build real nice .904 cams, (which doesnt matter here) but would expect there hyd roller cams to be just as good.
Anyways the spring # is 98432 and i would go next size cam bigger
They are similar. You can only go so fast using a hydraulic type lifter of any kind.
@ Moturbopar - Thanks - Seems they are billet cores so I'll probably look at an off the shelf Comp or Crane..Something inside me won't let me pay over $200 for an Oil drive gear for a street car.....:shock:
@ Moper - Dave - sent you an email outlining the possible plan...
I should also say that the D2000 sim I posted is seriously optomistic...
I downloaded D2003 yesterday and the outputs are much more conservative - I'll run apost of several sims on a seprate thread when I've input all my head flow and cam spec data,
