Mattax
Just the facts, ma'am
On that basis there's more power lost opening one valve!MUCH less than 1HP. You can operate a mechanical fuel pump by hand. I mean really.
It was something I seen on IG.Not me evidently. What did you search to find that? lol
"Custom" ....well we know what that program was for. LMAOIt was something I seen on IG.
You saying 1 hp and pumping by hand made me think of it in regards to that x rpm.
The skit goes... the guy designs an arm for amputees and in the midst of demonstrating it ...accidentally hits his own "custom" program button.
At least theres 'some' inertia with the pulley..as opposed to a water pump.I think you will find that the increased load through the alternator would be greater than the loss of running a mechanical pump and with that electric water pump that takes a lot of current to run this all has to be relpaced by the alternator!
He could have said he was a framer...but the wrist n grip was all wrong."Custom" ....well we know what that program was for. LMAO
lolHe could have said he was a framer...but the wrist n grip was all wrong.![]()
Was that the GI Joe Kung Fu grip?He could have said he was a framer...but the wrist n grip was all wrong.![]()
Time for rotary engineOn that basis there's more power lost opening one valve!
You expect everyone to read what you typed before replying?Not sure where everyone thinks I'm running an alternator?
I've hung a fuel can from the coat hanger. Actually worked pretty good for getting around town. LOLOf course someone could come up with a gravity fed system with a fish bowl on the roof if it really eats them that much..lol
I think that his combination is off. He's got a 650, he wants to use a air gap intake manifold, has a xe268 cam and spring's. Now for what's really going to cost him more power than a fuel pump ever will and that's the restrictive cylinder heads that he has, "302" heads with stock size valve's, those heads have around a 150cc intake runner size at best. I'm surprised that no one else caught this and no mention of a compression ratio either.On that basis there's more power lost opening one valve!
Not sure where everyone thinks I'm running an alternator? I'm not!! I see the one post about the alternator switch. Cool idea but I'd rather just charge the battery at the track.
The goal is to take as much load off of the 318 engine to gain the hp. If this was a 360 or big block I wouldn't worry about these little things. But given what this 318 is I do think every little thing the motor doesn't have to power will add up.
So to recap:
No alternator
Electric water pump
Electric fan
Electric fuel pump
Red top optima and battery charger
Goal is to hit 380hp with this little 318
Those heads are keeping you from getting the most out of your cam. Those heads are okay for a mild build but not for what you are wanting to doWe are running comp cams XE268H. Valves r stock size in the 302 swirl port heads.
I have a couple electric fuel pumps laying around so cost isn't the issue but If I get 5hp sounds like it would be worth it. Honestly shocked if it adds up to even 3hp but couldn't find any evidence to verify. Thanks for all inputs already fellas!!![]()
The voltage comment is pretty much what I said earlier, I'm glad that someone with more experience agreed with meThe alternator takes almost nothing to run. You’ll lose power giving it up because the voltage will drop. You are stepping over a donut to pick up a dog turd.
Contact 318willrun, he has tons of information and knowledge about making a 318 run. If you have a decent size radiator a quality electric fan probably would help.Dropping a mostly stock 318 into a friends car just to go racing this summer. Went with a moroso electric water pump and not running an alternator to free up some HP. As I was working on the car I wondered how much HP, if any, would the mechanical fuel pump cause an engine to lose? Did a quick google search and had no luck finding any results.
Given a mostly stock 318 would there be any hp gain, even 1 hp?, by doing an electric fuel pump instead of the mechanical fuel pump?
Thanks!!
