pntastar69
I currently have sbp rotors/hubs on the front of my Dart that were drilled to BBP. The steel wheels are bbp so the fronts are lug concentric. I've had these on for several years w/no issues but I will be making a few passes at a track rental coming up in May and considering ordering hub concentric rings as an added safety feature. From what I gather, the hub diameter is 2.32/2.33 and the bbp wheel center hole is 2.83.
Can anyone confirm these measurements?
Is anyone using hub concentric rings w/this combo, the size you are using and the supplier of the rings?
