Hopefully someone can help me out. I've had my 71 Demon for about 3 years now and I'm trying to wrap up my new instrument cluster swap. I also installed a Bluetooth amp which sounded great until I started the car and it began to cut in and out. After futzing around with the wiring I checked the voltage on the battery and noticed what you can see in the video below. When connecting the meter from negative and positive I'm getting a huge voltage drop while the car is running. It'll go down to close to 0 and back up to 13 which would explain why the amp is cutting out otherwise everything else electrical seems to work okay. When not running it sits solid at 12.7 or so. I don't have the instrument cluster in currently.
Here are some things I have tried and I am by no means proficient at electrical work. None of these things had any affect on the voltage dropping while running.
* replaced battery negative cable and cleaned connection to head
* cleaned and replaced ground from neg terminal to radiator support
* added ground strap on passenger side head bolt to firewall (this actually increased the max voltage at idle from 12.8 to 13.5 but voltage drop still occurs at battery)
* tried a different new battery
* new VR
* disconnected alternator
* basically disconnected everything behind the dash and pulled fuses and even pulled the bulkhead connectors (shorted the starter relay to start the engine) I assume this would isolate the issue to under the hood but I'm not sure...
That's all I can think of at the moment but I'm gonna go at it again tomorrow. I'm open to any suggestions like I said I'm not great at the electrical stuff. Thanks in advance!
* new VR
