dodge freak
Well my little 318 with MP 360 heads started to idle rough but seemed OK after 2500-3000 rpms. So I go ripping off the intake manifold and the Fel Pro intake gasket looks great :confused:
Then I pop the valve covers off, just had them up a 1/2 inch. Lord and behold 1 of the rocker shaft bolts snap off-at the end-and the rocker shaft was bent up--here I was worry about my rod bolts with my 6200 rpm red line it hits all the time 8)
Thank god I was able to get a easy out in the broken bolt and remove it without pulling the head off. Called up Hughes cause they had the banana grove rocker shafts and I got their rocker hold down stud kit--nice stuff but the new rocker shaft has only 1 set of oil holes, right were the banana groves are-no extra oil holes on the side like my old shafts. I could not afford to get Hughes rockers, just the shafts and are using the old style 273 adjustable rockers. Hughes said is SHOULD be OK without the extra side oil holes but I wounder if I should find a machine shop to drill the oil holes on the sides.
Should I be worry with just having oil holes-with groves-just on the bottom and not on the sides too ?
