HURRY! last min deal on alum radiator ebay... 1 hour
Whats the difference with the Duster radiators? Looks like it would work...
B body is wider and taller.
Later A-body's came with 26" radiators also. If it's only 22" tall as they say, it would fit an A-body without a problem.
Somebody got a great deal!
Good price, but what could it fit? The driver's side lower connection would only work w/ an early small block (cast-iron water pump). They don't say the size (1.5"D needed, I recall). Some big-blocks also had a driver's side port (my 65 Newport, recall), then they changed those also. Otherwise, the height and width "should fit".
I bought a new alum radiator (Be Cool, recall) for $80 on ebay, but wouldn't fit my 65 Dart unless I cut the frame rail lips (would fit wider 1967+ A's), so I put in my Newport. Now I will convert that car to waterless coolant (as did my M-B) so that valuable part will last.
