I would suggest pulling the dist/intergear (first line up a tooth dead even with the magnet for easy reassembly) then replace the pump & just barely snug the bolts then install the intergear/dist then final tighten/torque the pump bolts for a dead on pump hex/intergear hex alignment. before bolting on the pump turn its' hex to the same clocking as the hex is at on the old pump
