dadodgekid
When in doubt... floor it
Hey all, long time listener, first time caller... I'm doing a low budget Big block turbo build in a jeep wrangler. Its a basically stock 440 out of a motor home, steel crank, std bore, i re-ringed it and new bearings and i have a new timing set but two cams too choose from. I was wondering which will work better with my goals. Dont really care how much power, but i want to be able to boil off 40" tires...should be fun!! Ones a comp, .470" and 224* @.050 and 110 lobe seperation. the other is a old crane grind, .467 on I , .494 on E , duartion is 222/234 @ .050 on a 114 separation. Im leaning on the crane but since the comp is a single pattern, Ive heard it may work better. any input is greatly appriciated!! Thanks!
