hydraulic clutch release
baumtruck
Member
I have 71 dart ,440,hooker 2 inch fender well headers,lake wood bell houseing.I am installing a wilwood pull type hydraulic clutch release. The problem I am haveing is finding a mounting point for the clutch master cylinder.The upper fire wall area is a problem in that to get high enough to clear the headers I am above the clutch pedal pivet point . I am thinking of mounting it on top of the frame rail(where the zbar would be)at a up ward angle to connect with the stock clutch push rod.Has anyone got any ideas on this or used a similar set up?
