I have a hypothetical axle/ brake swap to run by you all. I have a '67 Barracuda with all new 8.75 rear end brakes, bearing, retainers, etc.. I want to go to a big bolt pattern in the rear. I have already done the 11 3/4 big disc swap in the front. My hypothetical question is if I buy new big bolt axles for the rear can I reuse my brakes? Now before I get various answers let me lay out the scenario in full:
New axles with 4.5" pattern for $200 (made for b-body brakes)
Add a .4" spacer between axle housing and existing brake backing plate and longer studs on end of housing.
R-edrill existing drums to 4.5" pattern
I know many will ask why keep the small brakes but with the 11.75's up front I really don't think I will need the bigger brakes.
Of course my other option is to get some Moser axles with the appropriate axle offset and just get the drums re-drilled but I wanted to just bounce an alternate idea off you all.
