MDchanic
Connoisseur d'Junque
On my newly acquired 1964 Dart, the choke spring will push the choke closed when cold, and the pull-off diaphragm appropriately cracks the choke once running, but as the engine warms up, the choke rod from the exhaust manifold to the carburetor goes slack and doesn't open the choke butterfly. If I disconnect the rod and open it with my finger, it will stay open easily.
Upon disassembly, the choke bimetallic spring has a single "hook" on the end, which rests against the rod, pushing it in the direction to close the choke when cold, but no part to grab the rod when moving in the opposite direction, so when the spring warms up, it pulls away from the rod, leaving it hanging.
Second Photo: With spring end outlined for clarity.
Is it broken? Missing a little attachment part? Anything else I should know?
And, no, I don't want to install an electric choke. Unnecessary complexity, which provides very minimal real improvement.
I'd have installed a manual choke already, but this dash has NO extra holes in it, and I don't want to be "the guy" who drilled it.
Thanks,
– Eric
Thanks,
– Eric
