My lawn is getting little brown spots!
Jeff
Jeff
I worked at a golf course in Florida and we would send to Oregon for winter seed. Bermuda grass would go dormant and brown and just before that we would seed it with an evergreen crass. And then in the spring time the Bermuda grass would choke out the thinly established Evergreen grass and on would continue our cycle. LOL
you're not fishing with that picture are you ?I worked at a golf course in Florida and we would send to Oregon for winter seed. Bermuda grass would go dormant and brown and just before that we would seed it with an evergreen crass. And then in the spring time the Bermuda grass would choke out the thinly established Evergreen grass and on would continue our cycle. LOL
And by far THE WINTER IS THE BEST SEASON!
BRAAAAAP....
If ya feel like your missing out, take a drive up our way...…… and just wear a T-shirt, you'll not need anything else.... 22* as I type, and still enuff white stuff to hit ya in the noggin with a snow ball
Don't need a calendar to tell me what time of the year it is.... Winter is cold and snowy, spring is rainy, summer is hot, fall has more colors than a crayon box.Only going to reach a high of 77 today. ...burrrrr!
Jeff
We don't get colors.....that kinda sucks...Don't need a calendar to tell me what time of the year it is.... Winter is cold and snowy, spring is rainy, summer is hot, fall has more colors than a crayon box.
Gonna drop into the teens next couple nights.
Been snowing all day . 8" on the ground . Up here , firewood delivered log length is about $100 per cord . Cut, split and delivered is about $300.00 for dry and $200.00 for green . There's no advantage to using wood unless you have your own wood lot . Even then ALL your time is spent processing the stuff. I'm in my 70's , i'm NOT doing that .
I have a ski hill across the road from me so they start making snow early as possible...all runs should be open real soon...maybe I should take up skiing...they do have an awesome tubing hill though
I have a wood stove in basement that can heat the whole house. Primary is heat pump/forced air and low temps the oil burner/hot water baseboard kicks in. I have bought some, but mostly burn wood I get free. I am 54. Don't mind cutting and moving it, but hand splitting is getting old as I get older. And not sure I will burn enough to justify cost of a splitterI turn 30 in about 2 weeks. I’ve still got a few firewood cutting days left in me. It’s not bad for me (yet), getting up in the middle of the night to fill the wood stoves does get old though.
Cheaper than oil/gas/electric for me, since I live in the middle of nowhere with trees as far as the eye can see.
