Reason I asked about rockers is if your running the adjustable rockers, maybe they backed off slightly allowing for a little slop until the lifters pump up.
I always use a bottle of zddp with every oil change , and change it every 2000 miles , 80% highway driving cruising at 70 - 80 mph , no short trips .
What royal purple oil should I use , and would it need zddp added . The garage I change oil at carries royal purple XPR 10 40 , 20-50 and HPS 10-40 , 20-50 , I use 10-40 weight synthetic oil now .
Remember too, too much zinc is also a bad thing.
It's confusing as hell , come say zinc or zddp is not needed after cam is broken in itherssay always needed , I always add a bottle of ZDDP , but never used a high zinc oil . Found this on RP site , guess Ill buy some XPR 10 40 and skip the zinc .Remember too, too much zinc is also a bad thing.
When rebuilt yes , that was 5 years ago , about 12,000 miles . Will look into it though . THANKSdid you replace the exhaust valve seats ? sometimes they get loose and sound like lifters noise and tighen up when they get hot, seen this many times on brand x before.
