Mopar-Man
Big Block Better Burnout
For my big block build. 10.5:1 470 what should I buy? I plan on locking out the timing and NOT running vacuum advance
the 470 is a low deck stroker correct? in this case the 8546 mentioned above is not correct. You need the 8545. linked below.For my big block build. 10.5:1 470 what should I buy? I plan on locking out the timing and NOT running vacuum advance
Billet Distributor MSD Ignition 8545 - Pace Performance Parts
Then i stand corrected and you have a few more options.RB BLOCK
I got the firecore billet distributor locked out in mine. it's very easy to adjust or lock and has been holding the timing nice and steady
