I need a rebuildable Holley 1920 or compatible 1bbl **CARB FOUND,THANKS GUYS**
1965 Dart GT
Member
Cen Cal
Rating - 0%
0   0   0
Like the title says, I need a rebuildable Holley 1920 carb. This is for my 65 225/904 Dart.
Tore mine down for rebuild but it has too much throttle shaft slop and a chunk missing from the body.
Not looking to spend much, just trying to drive enough for brake/light/vin inspection for pink... hoping to find something for less than $50 shipped.
I'd be interested in a 1945 or Carter or whatever bolts up if its cheap and either working or rebuildable. Only needed for temp use.
Shipping to 95380.
Thanks
I have a one barrel Holley on a 67 /6. The carb looks clean. I will check tomorrow to see what model number it is.
I have one that you can have for $25 including shipping. It is a Holley one barrel with following number on body "1452" & "6156". Will that work for you?
Let me know,
Bob
