[WANTED] I need lifters.
Anybody know where I can get some today?
First off. Let me introduce myself. My name is Jason. Just joined this forum. I have a 67 dart GT. This is my first time on a forum
I'm new to this. What more info?
Motor is out of a 71 roadrunner. But it could be a barracuda. At least that's what someone told me. Basically the same I found out
if you need them today, check a chain store and have them ordered. Should be there in 2-3 hours if your close to a hub. 340 doesnt need anything special, just hydraulics (if your rockers are stamped) solids (273 style ) are usually special order. Put assembly lube or moly grease on the faces and drop them in run motor dor 20 minutes at ~2500 then up and down a few times. High RPM makes sure the oil gets whipped up there from the crank.
Hey. I just want to thank everyone who responded to my thread. I got some and have them in now. They're hydrolic and I got them from summit. Came in three days.Running great again!!! Thanks again.
