I Need Some HEP! LOL
Bad Sport
HALF A BUBBLE OFF
Staff member
Legendary Member
The Wolverine State
Just came across these items, I know the ones in the tubes are end mills I believe, but the other item in the tool roll I haven't a clue.
Can someone shed some light on the subject?
Pilot reamers.
Edit. Typed that and then saw the screw sizes above the bit tips.
Spot face/recessed hole bores for screws.
And I guess I should add, how would they be used?
I noticed those end mills in the tubes were 20-25 bucks apiece.
Any idea on the cost of the others?
those look like pilot bits for enlarging holes or for drilling shoulder bolt holes
The tool roll pieces are:
Twentieth Century Manufacturing Company
Libertyville, Ill.
And they refer to them as Superbore.
Yep. pilot on the end should be 1/16 over the screw size and the cutter is 1/16 over the head size of as socket head cap screw .
We use them to counter sink holes for cap-screws
Yep....that's them.....the Pilot/Spigot good for when you require a spot face on and uneven surface.
Here is an example....although I modified a drill bit to do it.
spot face or counter bores used to make a surface for the bolt head to set on
