I think I goofed
gtdart
MI
First what is the going price on 4.11s gears(pig).
I just pulled this out of mywifes dart and put in a 2.75 gears. Is this pig (gear) posi? The 2.75?
You should be able to find a 4.10 ring and pinion in the $200.00 range. Setting it up should cost about $150.00. When you jacked the car up off the ground did both wheels rotate the same direction when spun? If so then you have a sure-grip.
