TT5.9mag
Two atmospheres are better than one
It won’t make too much difference but I’d lean towards the tighter end of the range. Whoever you order a converter from fill out their spec sheet and be as accurate and honest as you can and they’ll get you sorted out. But 2800-3000 tight, seems To be about right for your combo with a mild gear like a 3:23 or 3:55.Hey i pulled the cam I have up in Summit it shows the RPM range from 1,800 to 6,000 several on here agree with your 2800 tight converter recomdation, I know most converters have a range, 2800-3200 ect.. should i be looking for the 2800 to be at the higher end or the lower end of that range? Thanks again, Also on summit there were some recomendations for that cam to have a converter 2300-2500 but this was just a generic responce to cam alone that someone had asked,
