rcottick
340 engine with engine stand. Less than 200 mileson fresh rebuild. New trw 10.5-1 .030 inch over pistons and rings, blueprinted, balanced, decked and line bored. 8 bolt Kellogg crankshaft (never re-ground) and flywheel, ported heads with adjustable rockers and chrome valve covers, Mechanical lifters and DC .509 lift and 292 duration camshaft, DC double roller timing chain, Milodon oil pump and large capacity oil pan with windage tray, new edelbrock intake manifold, and electronic ignition distributor. No carb, alternator, water pump or misc brackets.
I am curious of what everyone thinks this is worth. I am planning on going to look at it.
Only question I have is what flexplate to use for this crank. Never heard of a Kellogg crank and its an 8 bolt
Ron
Ron
