zigs
Will a 1968 idler arm fit a 1973 bracket . I'm setting up for a 400 block.
No,it has to be 73-6 to fit the spool k frame. It goes : 67 only,68-72 and then 73-6 k frames and arms. They are not interchangable
What do you mean by bracket?
Yes you can put a 68-72 Idler in a 73-76 K-member. BUT YOU HAVE to run 68-72 centerline with a 72 or earlier small output spline power or manual steering box that has a pitman stud that point UP. So it take all four of those items together as a unit to swap.
I've ran the flip opposite of what you want to do: a 73-76: idler, centerlink, pitman, and steering box in a 1968-1972 K-member for years in my 1968 Barracuda.
