Ironmike
Posted this issue awhile back on the ignition sub-forum and got a few suggestions, but I decided I'd get more views here on the smallblock forum.
This is the situation: 1971 340 Demon. Came to me all original except for an Accel Street Billet distributor.(no ballass resistor required).
Drove the car for 2 months all over the place with no problems.
One day coming down my street it just died...like I turned it off. Tach dropped to zero and dead. Re started right away, got a block or so and died.
I kept restarting to get it home and could find nothing. At this point it was running good again. So It was now doing it intermittently so I replaced the entire ignition system trying to correct it.
Here's what I did: New magnetic pickup in the Accel distib, adjusted properly
New Accel 300+ MSD type ign box and coil
New voltage regulator
New starter/ignition relay
Checked batt voltage and alternator
Checked all my wiring connections
So fire it up ...run it for 45 minutes, all ok. Go for a nice long ride and ran GREAT.
Winter now here so me and a buddy install Doug's headers, Air Gap intake.....clean everything up and she looks beautiful. Fire it up to check for leaks...no lraks, sounds great, incredible off idle throttle response....WOW!
just HAD to take a little ride with open headers just for fun. Pull out of my driveway and...........it dies. IT AIN"T FIXED afterall.
Now I'm desperate. Only 1 wire goes to the ignition(12V wire from ign switch), so I run a 12V straight from the batt and it STILL dies.
What I found out was it will only restart if you turn the ign switch all the way back to off. If try a restart without doing this, it will just crank all day.
I am at the point of real desperation. Can it be the ign switch, even though It died with the 12v line jumped?
Can it be the batt or alt shorting or spiking?
Can something other than the pick-up go bad in the distrib? It is the only ign part not completely replaced.
Starter?
Something obviously must need "reset" due to the ign needing to be turned to the off position before a restart will happen.
I am so, so sorry for the long post, but at this point, I have nowhere else to turn.
Starter?
