2 Darts
A-body Addicted
I have a problem with the ignition lock on my 73 Dart. The lock will not accept the keys I have for it and it is stuck in the on position. The steering wheel on the other hand, is locked into position. I am planning to replace the ignition and door lock cylinders.
Other than to disconnect the battery and plow through stripping the column down to the turn signal switch, I'm kind of lost. I have the FSM which doesn't seem to be a lot of help. Any practical tips that can be provided will be appreciated.
