[Found!] ignition switch light
FYI I’m told my harness includes the wiring for the light but I don’t know any better. I’m not sure my column is the original factory one or not. I don’t see where the light would fit but I don’t know what to look for.
If you have a 1970 steering column this what you need.
I am looking for the 1970 under the dash light package harness myself.
I have the column light for my car
Just based on what I've seen, the light at the ignition switch is/was more common to a loaded 4 dr Dart/Valiant. The timer operates courtesy lamps, i.e. dome lamp / all yellow wire lamps, so it could be found in lots of builds that didn't get the lamp at ignition switch.
