[SOLD] Ignition Switch w/Key
65 Dartman
1 of None 65 Dart Sedan Delivery
Strasburg, VA
I have what I believe is an ignition switch with key from a 69 Charger as that is the only 69 I’ve ever parted out. I “think” this switch will also fit a 69 A Body. Original Key turns freely with no binding. $35 plus shipping from 22657
That's a '69 switch. They do make a 5 and 6 terminal version however. Being this is a 6, it will fit both applications. A 5 terminal one doesn't have the ground connection.
The reason for the error is when you PM someone, the message you send is stored in your PM inbox, which is full. Clear your PMs and you can send one OR i can send one to you.
